China Ceramic Ball As Filler
dwpyy12
Ваш Город: hangzhou
Сообщение dwpyy12 » 02 апр 2019, 04:45
Chemical Name: 20-80% Alumina Filling Ball
Synonyms: Alumina oxide balls, Alumina filling Ball, Inert alumina filling ball, Inert ceramic ball
Molecular Formula: Al2O3
CAS No.:1344-28-1
H.S. CODE: 69091100.00
Characteristics:
High strength,high temperature resistant,excellent compression resistance,excellent corrosion resistant
Applications:
(1)Metallic minerals like copper, silver, nickel, gold, zinc etc.
(2)Non-metallic minerals like Calcium Carbonate, kaolin clay, zirconium silicate, TiO2 and other minerals.
(3)White pigments, coatings, paints, inks etc.
Specification:
ItemAl2O3 (%)607080
Fe2O3 (%)≤0.9≤0.8≤0.6
we can also produce as customer required
Water absorption3±1 or as customized
Bulk Density (kg/m3)2.5-3.02.7-3.22.9-3.2
Packing Density (kg/m3)1400-15501400-16501500-1800
Broken (%)<5% per bag
Free fallingNo broken ≥99%
Whiteness50-7555-7560-80
Acid Dissolved (%)≤6
Alkaline Dissolved(%)≥77≥85≥90
Anti high Tm≥400≥500≥700
Anti Quick pressure change(%)no broken≥99%
Anti quick Tm change(%)no broken≥99%
Diameter(mm)3mm,6mm,8mm,10mm,13mm,19mm,25mm,38mm,50mm,75mm
Packing: 20kg,25kg,40kg,50kg woven bag
FAQ:
(1) Sample: Available
(2) MOQ: 2 Tons.
(3) Payment: L/C, TT
(4) MSDS: AvailableChina Ceramic Ball As Filler
website:http://www.china-activatedaluminaball.com/ceramic-ball/ceramic-ball-as-filler/
Вернуться в «Ходовая часть»
