Design Stop Bark Control
dwpyy12
Ваш Город: hangzhou
Сообщение dwpyy12 » 02 апр 2019, 04:48
CSB11 Indoor Ultrasonic Bark Control, Stop Barking up to 25 ft range, No Collar Needed, Anti-Bark
•Works on all dogs within hearing range
•For indoor use only
•Stops your dog's constant barking almost like magic,for dogs 6 months and older
•Uses high-frequency ultrasonic sound to disrupt nuisance barking-- no collar needed
•Table-top, wall-mounted or hand-held use to fit the needs of your household
•Range up to 25 feet (about the size of 1-2 rooms of a home)
•Two settings: you can set the unit to automatically emit the ultrasonic tone when your dog barks or press the manual button to correct inappropriate behavior
•No bark guarantee: Some dogs may not be responsive to ultrasonic correction. If this product is not meeting your needs, please contact Redmogo Brand
How it works
When the indoor bark control unit is within range of a barking dog, an internal microphone picks up the sound. The unit automatically emits an ultrasonic tone that can be heard by dogs but is silent to humans. Startled by the high-pitched tone, the dog should stop barking. In time it will associate its bark with this unpleasant noise. When the dog stops barking, the ultrasonic tone also stops. It is effective up to 8 meters.
You may also use the indoor bark control unit as a remote trainer. When your pet exhibits inappropriate behaviour, press the manual control button the unit to emit an ultrasonic tone. The dog should be startled by the high-pitched tone and stop his poor behaviour.
Features
●automatically corrects excessive barking
●activated automatically or manually
●no receiver collar needed
●detects barks up to 8 meters away
Key Definitions
Microphone: detects barking up to 8 meters away.
Two colour LED: shows good or low battery.
Speaker: produces the ultrasonic sound.
Button: manual control activates an ultrasonic tone on demand
Battery door: used to enclose the 9v battery
Keyholes: provision for wall mounting
Setup
The indoor bark control should be placed facing the dog, within a range not to exceed 8 meters. For best results, the area between the indoor bark control and the dog should be free of any large obstacles.
To insert and remove the battery
The indoor bark control requires a 9-volt battery(not included).
The battery door is located on the back of the unit. Pull the battery door open.
Install the 9-volt battery with the positive side oriented as shown.
Replace the battery door by positioning the top edge, and snap the bottom of battery door into place.
Battery life
Average battery life is 2 months, depending on how often the dog barks. To conserve battery life, remove the battery when the indoor bark control is not in use.
Two colour LED
The two colour LED indicator shows good or low battery. Good battery equals 1 flash every 5 seconds with green LED. Low battery equals 3 flashes every 5 seconds with the red LED. If there are no LED lights it is time to change the battery.
What to expect during use of the indoor bark control
Place the indoor bark control within 8meters or less of the dog. When the microphone picks up the constant bark of the dog, it will emit a 2-second high-pitched ultrasonic tone. While the tone cannot be heard by humans, it should startle the dog. Most dogs will understand very quickly that the indoor bark control is disrupting their urge to bark and will relax and stop barking.You should notice a reduction in the dog’s barking within the first 2 weeks that the indoor bark control is in use.
Eliminating unwanted behaviour
To eliminate other unwanted behaviour(i.e. jumping on furniture), the manual activation function can be used.
As soon as your pet begins the earliest sign of misbehaviour, press the manual control button. For example, if you want to teach your dog to stay off the couch, press the button as soon as he puts one paw on the seat. Do not wait until he is completely on the couch.
1.hold the manual button for up to 2 seconds, releasing the button as soon as your pet stops the misbehaviour.
2.if your pet has not stopped the misbehaviour after 2 seconds of correction, release the manual button; then press it again for up to 2 seconds.
3.continue this sequence until the misbehaviour has stopped.
4.once the misbehaviour has stopped, reward your pet with praise.
Regular maintenance
◆remove the battery before cleaning.
◆Clean the indoor bark control with a damp cloth
◆Do not use any kind of spray chemicals or solvent to clean.
◆Do not immerse in water or any other liquid.
◆Keep away from children. Small parts may cause choking or serious injury if swallowed.
◆Avoid exposing your device to very cold or very hot temperatures (below 0℃ or above 45℃ ). Extreme temperatures can cause the deformation of the device and reduct the charging capacity and life of your device.
Customer care
Please contact your local customer care center with any set-up or technical difficulties you experience, and if necessary assist in the replacement of your product.
Frequently asked questions
Q: what is the range for the indoor bark control?
A: the indoor bark control detects barking and sends the ultrasonic tone up to 8 meters.
Q: is the indoor bark control effective on all dogs?
A: the product may not work on deaf or hearing impaired dogs.
Q: will the indoor bark control work for multiple dogs?
A: yes it is effective on all dogs within the 8 meters range.
Q: can I mount the indoor bark control outdoors?
A: no, we do not recommend keeping the product outdoors.
Q: can a dog become desensitized to the ultrasonic sound?
A: there are some situations where dogs become desensitized. To avoid this, only use the indoor bark control during periods of unwanted barking(i.e., remove the battery when you are away).
Battery disposal
Separate collection of spent batteries is required in many regions; check the regulations in your area before discarding spent batteries. Please see page 8 for instructions on how to remove the battery pack from the product for separate disposal. This device operates on 1, 9 volt alkaline battery; replace only with equivalent battery.
Important recycling advice
Please respect the waste electrical and electronic equipment regulations in your country. This equipment must be recycled. if you no longer require this equipment, do not place it in the normal municipal waste system. Please return it to where it was purchased in order that it can be placed in our recycling system.
Terms of use and limitation of liability
1.Terms of use
use of this product is subject to your acceptance without modification of the terms, conditions and notices contained herein. Use of this product implies acceptance of all such terms, conditions and notices. If you do not wish to accept these terms, conditions and notices, please return the product, unused, in its original packaging and at your own cost and risk to the relevant customer care centre together with proof of purchase for a full refund.
2.Proper use
this product is designed for use with pets where training is desired. The specific temperament or size/weight of your pet may not be suitable for this product(please refer to “how the system works” in this operating guide). Recommends this product is not used if your pet is aggressive and accepts no liability for determining suitability in individual cases. if you are unsure whether this product is appropriate for your pet, please consult your veterinarian or certified trainer prior to use. Proper use includes, without limitation, reviewing the entire operating guide and any specific caution statements.
3.No unlawful or prohibited use
this product is designed for use with pets only. This pet training device is not intended to harm, injure or provoke. Using this product in a way that is not intended could result in violation of federal, state or local laws.
4.Limitation of liability
in no event shall our company or any of its associated companies be liable for(1) any indirect, punitive, incidental, special or consequential damage and /or(2) any loss or damages whatsoever arising out of or connected with the misuse of this product. The purchaser assumes all risks and liability from the use of this product to the fullest extent permissible by low. For the avoidance of doubt, nothing in this clause 4 shall limit our company liability for human death or personal injury or fraud or fraudulent misrepresentation.
5.Modification of terms and conditions
our company reserves the right to change the terms, conditions and notices governing this product from time to time. If such changes have been notified to you prior to your use of this product, they shall be binding on you as if incorporated herein.
IMPORTANT SAFETY INFORMATION
Explanation of attention words and symbols used in this guide
!: This is the safety alert symbol. It is used to alert you to potential personal injury hazards. Obey all safety messages that follow this symbol to avoid possible injury or death.
WARNING: indicates a hazardous situation which, if not avoided, could result in death or serious injury.
CAUTION: used with the safety alert symbol, indicates a hazardous situation which, if not avoided, could result in minor or moderate injury.
Used without the safety alert symbol, indicates a hazardous situation which, if not avoided, could result in harm to your pet.
NOTICE: is used to address practices not related to personal injury.
WARNING: not for use with aggressive dogs. Do not use this product if your dog is aggressive, or if your dog is prone to aggressive behaviour. Aggressive dogs can cause severe injury and even death to their owner and others. If you are unsure whether this product is appropriate for your dog, please consult your veterinarian or a certified trainer. do not submerge in water. Do not open .keep out of reach of babies to avoid choke risk.
CAUTION: humans cannot hear the ultrasonic sound; however, precautions should be taken when using the indoor bark control.
Humans should also avoid standing very close to the indoor bark control when it is operational.
Not for use by children.
This device is intended for use only with dogs. Never attempt to use it for any purpose not described in this manual.
All pets in hearing range will be affected by the ultrasonic tone.
NOTICE: if the dog is deaf or hearing impaired, he may not react to the indoor bark control.
The indoor bark control is weather-resistant, not waterproof. However, if water enters into the microphone it may disrupt the unit`s operation. After the microphone dries, it will resume working properly.Design Stop Bark Control
website:http://www.sunwayes.com/stop-bark-control/
Вернуться в «Ходовая часть»
