PE Foam Tape factory
xuqing
Сообщение xuqing » 19 апр 2019, 09:02
PE Acrylic Foam Adhesive Tape
Product Description of PE Acrylic Foam Adhesive Tape
PE acrylic foam adhesive tape is PE foam backing coated with acrylic adhesive. It is shockproof, soundproof and airproof. It coheres well to various kinds of surface. Mainly used for the exterior and interior automotive decoration and nameplate.
Product Features of PE Acrylic Foam Adhesive Tape
• Excellent adhesion
• Sound insulation
• Shockproof
• Conforms to various kinds of surface
Construction of PE Acrylic Foam Adhesive Tape
Acrylic Adhesive
PE Foam
Acrylic Adhesive
Release Film / Paper
Data sheet of PE Acrylic Foam Adhesive Tape
ItemPE Acrylic Foam Adhesive Tape
Tape Thickness (mm)1.0±0.1, 2.0±0.1
Backing MaterialPE Foam
AdhesiveAcrylic
ColorWhite, Black
180°Peel Adhesion (N/25mm)≥14
Holding Power (Hr/25mmx25mm/kg, 25℃)≥24
Release Linerfilm/paper, colors: red, green, blue/white, yellow, etc.
Jumbo Roll Size1020mm x 300m
Application of PE Acrylic Foam Adhesive Tape
• Fixing the nameplate
• Automotive - mirror, door sealing strips, pedal and metal boards
• Glass curtain wall and soundproof wall
• Car decorations
• Combination orientation of sound source inside the voice boxPE Foam Tape factory
website:http://www.weishen-adhesive-tapes.com/pe-foam-tape/
Вернуться в «Ходовая часть»
